Visibility State Selection in Properties Panel's Parameter Field Not Working for User
EDITED: Are there any known issues among the BricsCAD flavors of the V22.1.07 (x64) release where the 2D parametric block's visibility state selection dropdown list does not appear for users.
Creating my first parametric block today (see the attached DWG file), the dropdown list appears with the installation of BricsCAD BIM on my computer but is not appearing on my colleague's installation/ computer.
Attached are a screenshot of the results on both computers as well as the DWG file used in this test.
Hello.
I tested with V24.2.06, V23.2.07, V22.2.06, and V21.2.07, and they all worked the same - the drop-down was available for selecting values.
What happens when the value field is clicked?
Pardon my extended time away from your inquiry. BricsCAD support provided the answer.
The issue is caused by a V22-related issue where certain special characters are not recognized.
In my case, the " mark caused the failure. I was also advised to upgrade as this issue was fixed in V23.
Last week, our users were updated to the current, V24, release. Now, this is not an issue.
P.S.: I will monitor this forum much more often. Your replies and suggestions are welcome and will be responded to in a timelier fashion.
Thanks,
Clint
