Connect a TIN surface to a boundary
Hi!
Is it possible to get the TIN surface I've done from points to also connect to a line/boundary like the one I've marked in the attached picture. The polyline also have different Z levels.
Now the triangels go between the points ofcourse, but i want the surface to go all the way out to the rounded corners.
The light blue area is a gravel surface and the polyline I've marked is the edge of the asphalt surface (red surface).
(I know the color choices are wierd but I'm just playing around to learn how to use the softare).
Cheers!
  • try the TIN command and select the points AND the polyline, then use one of the 3 options for the polyline
    Apply linear entities as ? [Points/Edges/Breaklines]
    Select entities to create TIN surface or [Import from file/place Points/create from Faces/create from point Cloud/create from point Groups/create from cOntours/cLip polygon/selection options (?)]:
    Selection contains linear entities. Apply linear entities as ? [Points/Edges/Breaklines] <Points>: p
    Is that what you need
  • Perfect, thank you again Sakko!
