.Net: _AcBim.BIMPropertySet.ListProperties
Hello,
just a quick question regarding the BIMPropertySet "ListProperties" method.
Shouldn't the output of:
_AcBim.BIMPropertySet.ListProperties("demo", db);
match the output of:
(bim:pset-list-properties "demo")
Using the same document (where "demo" is a custom User defined pset)?
When I inspect (or dump) the contents of the .Net version result (List<List<string») it contains the same property multiple times (instead of all defined properties).
Thanks in advance & best regards,
Jason
  • From your description it sounds like a bug. I recommend creating a support ticket so this can be investigated.
