Question in regards to constraints
Hello.
I was wondering if there is a way to show the constraints in an assembly underneath the individual parts (akin to what Autodesk Inventor does) to make it easier to navigate and find the right constraints in big structures?
or would the only method of 'organizing' it be to name the constraints manually to make it more clear that way?
  • Hello.
    For 3D geometric constraints, there are no icons displayed in the drawing area.
    This feature exists only for 2D constraints.
    One way of working could be to enable the "Group by entity" option in Mechanical Browser.
    This way, the constraints assigned to a certain entity will be listed in a tree structure under the entity's name.
    Then, by selecting an entity in the drawing area will highlight its name in Mechanical Browser, so the associated constraints will be easier accessible.
