insert block from another drawing
Does BricsCAD have an equivalent to AutoCAD's "-insertcontent" command?
This command will insert a block from an external drawing without inserting the entire drawing first.
copy paste? also, you can use the drawing explorer, copy the block from one drawing and paste into another
Thanks, I am aware of these other options.
The command I was asking about can be used in lisp to insert blocks without the entire file.
Oh, maybe you can use a combo of wblock and insert.
1 -
Have a look at Lee-mac.com Steal.lsp it allows you to "STEAL" a block from another dwg, it also has way more options than just a block, from a programming point of view can be as simple as 3 lines of code. The 1st line loads the steal.lsp. Then you just ask for what you want does not need user input.
Thanks Alan, I will check this out
