BIM Section Blocks Placed Next to Each Other
Good morning,
For some time now, I have been experiencing this issue when creating print layouts for models created with BricsCAD BIM. After creating the sections with BimSectionUpdate, I find that the generated blocks are placed next to each other: is there a way to space them apart?
  • hi Davide,
    the setting BIM/ 'Section result interval' sets the distance between the boundingboxes of the section resultblocks.
  • Thank you,
    I would have never figured it out. I was looking in the sheetset options. Why did they set it to 0? Strange.
  • That is indeed strange, default should be 10meter. In my install it is.
