There is no possibility to create dynamic blocks in BricsCAD, there are parametric blocks instead of dynamic, though existing dynamic blocks could be used as well. Also there is a possibility to convert existing dynamic blocks to parametric via BLOCKCONVERT command.
For additional information about parametric blocks please refer this Help acticle.
Making dynamic blocks in bricscad.
For additional information about parametric blocks please refer this Help acticle.0 -
Thank you very much.
I have tried several times to convert different dynamic blocks into parametric blocks, but every time I get an error stating that some parts of the dynamic block is not supported and the block can not be converted.
Yes, currently not all dynamic blocks might be properly reconstructed as parametric blocks. We are working on BLOCKCONVERT command to improve this.
