Parametric block problem
I have a block in BricsCAD with a parametric stretch operation. When I open it in AutoCAD, the block appears without a name and without the parametric stretch option.
BricsCAD parametric blocks are only parametric within BricsCAD. In AutoCAD they will be a simple block. If you have manipulated the parametric block away from its default state in BricsCAD, then that instance of the block will be represented as an anonymous block, which is why you wouldn't necessarily see the name in AutoCAD.
AutoCAD Dynamic blocks work in a similar manner.
1
