Edge Created each time I extrude a face from a solid
edited September 2024 in 3D Modeling
Starting today, every time I extrude a face from a solid, a edge is created at the start of the extrude location. Normally, if the extrusion is in the same direction, no edge is created or required, it is very annoying because now I need to select every face individually if I want to extrude further.. My setting for ''Extrude behavior outside'' has not change, it is still (2)Unite the entities.
Also when I use the Union Command now, edges from all the entities are still visible instead of just merging into a flat face.
  • Ok I think it was a glitch in the program. I restarted Bricscad and now it behaves like it should. I hate when an issue is resolve without any apparent reason!
