Excel to DXF dimension text and arrow enlargement
Can someone guide me on how to properly enlarge dimension text and arrowheads in a DXF file generated from VBA?
I’ve been working on a project in Excel to simplify some calculations, and I came up with the idea to generate a preliminary drawing via a DXF file instead of importing results into BricsCAD using coordinates.
I'm facing an issue with enlarging the dimension text and arrowheads in the DXF file. I've tried scaling the text, but it creates issues during later editing, so that's clearly the wrong method. I’ve used code 40 for regular text, and it works fine, but it doesn’t seem to apply to dimension text. I’m also worried that I may have broken something else in the process.
My code is functional in terms of drawing lines and adding dimensions (with rounding to 5 cm and handling negative values). However, I can't figure out how to change the size of the dimension text or the arrowheads. I also tried moving the dimension text vertically, but for some reason, I can only shift it sideways.
Has anyone else experienced this problem?
Sub DodajWymiarowanie(fileNumber As Integer)
Dim lastRow As Long
Dim i As Long
Dim firstDataRow As Long
Dim wymiar As String
Dim odleglosc As Double
Dim roznicaY As Double
' Znajdź pierwszy i ostatni wiersz z danymi w kolumnie B i C
firstDataRow = 13 ' Ustalenie startu od wiersza 13
lastRow = Cells(Rows.Count, 2).End(xlUp).Row ' Ostatni wiersz z danymi w kolumnie B
' Dodanie wymiarowania liniowego w pliku DXF
For i = firstDataRow To lastRow
' Sprawdzenie, czy są dane w kolumnach B, C oraz I, J, oraz pomijanie pierwszego i ostatniego wiersza
If i <> firstDataRow And i <> lastRow Then
If IsNumeric(Cells(i, 2).Value) And IsNumeric(Cells(i, 3).Value) And IsNumeric(Cells(i, 9).Value) And IsNumeric(Cells(i, 10).Value) Then
' Oblicz odległość między punktami
odleglosc = Sqr((Cells(i, 9).Value - Cells(i, 2).Value) ^ 2 + (Cells(i, 10).Value - Cells(i, 3).Value) ^ 2)
' Obliczenie różnicy między wartościami Y z kolumny C i J
roznicaY = Cells(i, 3).Value - Cells(i, 10).Value
' Zaokrąglenie odległości do najbliższych 5 cm i dodanie minusa lub plusa w zależności od różnicy
If roznicaY < -0.024999 Then
wymiar = "-" & FormatZaokraglenieDo5cm(odleglosc) & "m" ' Dodanie minusa, jeśli różnica jest ujemna
Else
wymiar = FormatZaokraglenieDo5cm(odleglosc) & "m" ' Standardowy wymiar, jeśli różnica jest dodatnia
End If
' Dodaj wymiarowanie pomiędzy punktami
Print #fileNumber, "0"
Print #fileNumber, "DIMENSION"
Print #fileNumber, "8"
Print #fileNumber, "WYMIAROWANIE"
' Ustawienie koloru na niebieski (DXF color code 5)
Print #fileNumber, "62"
Print #fileNumber, "5" ' Kod koloru dla niebieskiego
Print #fileNumber, "100"
Print #fileNumber, "AcDbAlignedDimension"
' Środkowy punkt wymiarowania (gdzie pojawi się tekst wymiarowy)
Print #fileNumber, "10" ' Punkt wymiarowy X
Print #fileNumber, Replace(Format((Cells(i, 2).Value + Cells(i, 9).Value) / 2, "0.000"), ",", ".")
Print #fileNumber, "20" ' Punkt wymiarowy Y
Print #fileNumber, Replace(Format((Cells(i, 3).Value + Cells(i, 10).Value) / 2, "0.000"), ",", ".")
Print #fileNumber, "30" ' Współrzędna Z
Print #fileNumber, "0.0"
' Dodaj wartość wymiaru z powiększeniem
Print #fileNumber, "1" ' Tekst wymiarowy
Print #fileNumber, "\H11.1111111111x;" & wymiar ' Dodanie wymiaru po zaokrągleniu i powiększenia
' Punkty bazowe (Początkowy i końcowy punkt wymiarowania)
Print #fileNumber, "13" ' Punkt początkowy X
Print #fileNumber, Replace(Format(Cells(i, 2).Value, "0.000"), ",", ".")
Print #fileNumber, "23" ' Punkt początkowy Y
Print #fileNumber, Replace(Format(Cells(i, 3).Value, "0.000"), ",", ".")
Print #fileNumber, "33"
Print #fileNumber, "0.0" ' Z
Print #fileNumber, "14" ' Punkt końcowy X
Print #fileNumber, Replace(Format(Cells(i, 9).Value, "0.000"), ",", ".")
Print #fileNumber, "24" ' Punkt końcowy Y
Print #fileNumber, Replace(Format(Cells(i, 10).Value, "0.000"), ",", ".")
Print #fileNumber, "34"
' Wartość wymiaru
Print #fileNumber, "50" ' Kąt wymiarowania
' Wymiarowanie wyśrodkowane
Print #fileNumber, "70" ' Flaga wymiarowania (aligned)
Print #fileNumber, "1" ' Aligned dimension
' Zakończ wymiarowanie
Print #fileNumber, "SEQEND"
End If
End If
Next i
End Sub
Function FormatZaokraglenieDo5cm(wartosc As Double) As String
' Zaokrąglanie wartości do najbliższych 5 cm (0.05 metra)
Dim zaokraglonaWartosc As Double
zaokraglonaWartosc = Round(wartosc * 20, 0) / 20
' Sprawdzenie, czy liczba kończy się na .05 lub .15 (itd.) - wtedy pokazujemy dwa miejsca po przecinku
If zaokraglonaWartosc * 100 Mod 10 = 5 Then
FormatZaokraglenieDo5cm = Format(zaokraglonaWartosc, "0.00") ' Dwa miejsca po przecinku
Else
' W przeciwnym wypadku pokazujemy jedno miejsce po przecinku
FormatZaokraglenieDo5cm = Format(zaokraglonaWartosc, "0.0")
End If
End Function
What I've already tried:
Print #fileNumber, "\H11.1111111111x;"` ' It works, but it's not the proper method for further text processing. ' Ustawienie wysokości tekstu dla każdego wymiaru Print #fileNumber, "40" Print #fileNumber, "4.0" ' Wysokość tekstu ustawiona na 4 jednostki` - doesn't work Const DEFAULT_FONT_SIZE As Double = 2.0 Print #fileNumber, "9" Print #fileNumber, "$DIMTXT" Print #fileNumber, "40" Print #fileNumber, "2.0" ' Powiększenie strzałek (42) oraz tekstu wymiarowego (140)
Print #fileNumber, "42" ' Wielkość strzałek
Print #fileNumber, "2.5" ' Powiększ strzałki do 2.5 jednostek
Print #fileNumber, "140" ' Wielkość tekstu wymiarowego
Print #fileNumber, "3.0" ' Powiększ tekst do 3 jednostek
I do not work with VBA, but described effects suggest problems with dimension styles and related with them system variables.
1 -
Hello.
Something worth noting could be that a dimension is a combined entity, like a block.
The dimension entity contains some geometric entities - the lines and the arrow symbols - and a MTEXT entity, used to display the value and other texts.In fact, the dimension text height is specific to the mtext sub-entity, and not to the dimension itself.
Given this, it seems very complicated to adjust the dimension text height while programmatically creating a dxf file from scratch.
This would require in-depth knowledge about the dxf codes and especially about the structure of a dxf file.Maybe, an approach could be to create an empty drawing template with some custom settings.
This drawing could be saved as dxf and used as a header and a footer.Then, the workflow could create a new dxf file, write the header, write the custom content - the dimensions, and write the footer.
This way, the dimension will use the exisitng custom settings - text style, dimensions style, ... - as set in the original template.
1 -
jbn1 partially guided me toward a solution to the problem, along with someone from another forum who confirmed that this piece of code looks fine. The changes had to be made elsewhere. I still have some chaos in my file, with dimensioning text being set in several places, but through trial and error, I managed to figure it out. Overall, I think it would be very difficult to edit a DXF file without completely overwriting it using VBA. I have a separate file where I normally draw what I decided to automate a bit, and now I want to paste this DXF into that file. I’ve managed to enlarge both the dimensioning text and arrows, which is a big success. However, as soon as I copy the entire drawing into the main file, both the dimensioning text and arrows shrink for some reason. This issue has happened to me before with DWG files, so I think it’s partly a BricsCAD bug. When we used AutoCAD, this never happened—AutoCAD never rescaled my objects when copying.
Why not just draw in Bricscad no need for a dxf, open a blank dwg, you need to make subs for each entity.
I only dabbled with this. As I normally read a excel direct and make objects.
