Door Swing
I'm new to BricsCAD and BIM. I'm just trying to insert doors and they are swinging in the wrong direction. I can flip the door from one side of the wall to the other but I can't work out how to swap the swing from left to right. I'm just using the default doors from Bricscad.
Cheers
Mick
It is the same command:
: _BIMFLIP
Entities in set: 1
Flip insert(s) [Left-right/In-out] <Left-right>: _LBut in the quad panel there are 2 icons:
