Need help Toolbar problem
Hello!
I accidentally did something silly and completely lost my toolbar. I received a tip to go back to default settings, which was supposed to solve the issue. I did that, and sure, everything else came back, but not the MagiCad tabs.
Do you know how I can get them back? I've been banging my head against the wall and can't figure out what to do. I've tried reinstalling everything, but it still doesn't work. I can see that MagiCad starts when I open a model, but none of the tabs appear in the toolbar.
  • That looks like a ribbon not Toolbar. You could see if you have a Magicad.CUI and use menuload.
    Yes have screwed up the menu's at times and can be a pain to get back finding various CUI etc.
    I would suggest when getting it to work save a profile and we set user named Workspaces. So did not edit the defaults.
  • Thank you! It worked!
