Modelling the Ground
Hello All,
What is the best method to create a ground plane from points (I have a point cloud attached via Cloudworx) that is not flat. I was thinking TIN but how editable are this after creation. Can you mark on white lining for example say by intersecting it.
I've thrown myself in the deep endd wit ha large warehouse unit and it's surrounding car park, and am modelling it into 3D with the intention of then "Bimifying" it after.
Hello.
The TIN command has an option to create a TIN surface from a point cloud.
However, this works with point clouds attached directly in Bricscad.I am not sure if the procedure could work with a point cloud attached with Cloudworx.
If the TIN command cannot use the point cloud, then, maybe, Cloudworx can export the points to an outer file.
Then, the TIN surface could be created using that file.0 -
Thanks,
Been really busy, but will have a play over Xmas.
Jack and the Beanstalk, or Cinderella? Break a leg!
1 -
Ha Ha 😉
