Convert blocks to components
Good day to you. I have a problem: when opening a file created in version 23, some components were converted into mechanical blocks in version 22. Can you tell me if they can be converted back into components?
  • Hello.
    In my testing, the attached drawing displayed mechanical components.
    However, you could try an approach like this:
    — Set MECHANICALBLOCKS = 0.
    — Run BMMECH.
    — > Accept the default name for the root component.
    — > Select the entities to be converted to mechanical components.
    — Save the drawing with another name.
    — Check whether the previously selected entities are mechanical components.
  • Thank you very much for your answer!!!!
