Weird performance problem with bricscad and citrix only into the drawing (2d)
edited October 2024 in Other
Hi, sometimes i work from home, but i have a weird performance issue:
When i point the mouse on the toolbars the performance is very smooth, but as i enter a drawing the pointer moves very sluggishly, I don't have this problem when i work at place. I tried to set the drivers both on my pc at home and on the work one the max performance possible without v-sync, antialiasing, anisotropic filtering etc…, i've even set high performance profile for citrix and bricscad with no avail. I don't think is a home pc issue, because i have a ryzen 5800x3d, 32 gb ram 3200mhz cl14, gpu 3070 ti and a fast 300mb fiber connection. The workstation: i7 9700, 16 gb ram , gpu quadro 4000, 1gb fiber connection.
My collegues working from home said they have the same performance on the toolbars and into the drawing. i can't figure out why is only happening to me, and i have way better pc at home than them.
