Plate Auto dimensioning of plate is not working in BricsCAD
in LISP
Hi!
I have an issue for plate auto dimensioning. it works great in AutoCAD but BricsCAD doesn't work.
I have an attached both outout. and also Code.
Hello.
There might be some systems settings that are not exactly the same in Autocad and Bricscad.
For instance, you could test with disabling the entity snap before auto-dimensioning.0 -
Simple glance looks like a osnap problem.
Post code. Or looks like a link to a forums/autodesk
Attached my lisp
You need to post the code without your licence testing.
You should never post code with how your security testing.
