Adding a bitmap or texture to sheet metal cylinder
For Brics Mech V23, trying to add a "dimple" pattern to a sheet metal cylinder or pipe. Tried using materials dialog but seems to only look right on a flat surface. Anyone have experience doing this and have some tips? Attached is a pic of a typical dimple pattern.
You need to use the MATERIALMAP command
This allows you to assign different material projections to the faces of your object, such as cylindrical.
With your material definition you would also need to look at creating a bump map to compliment your image.
Thanks Jason that helped, had to mess with the "toggles" a bit but eventually got there.
1
