QuickDraw do not use snap
I can not use snap to endpoint when use QuickDraw. is this an error?
  • Strange, seems only to work when I zoom in very closely.
    I can see a green snap marker but it seems to not really stick.
    I tried to draw a 2D Line on the floor of the quick draw building.
    And it was nearly impossible to deactivate the middle of area snap.
    I opened 3D snaps palette and was not able to deactivate it,
    when I activated other modes it may have deactivated itself but came
    back. And I was not able to set all my modes without losing one or
    other at the same time.
    Had to go to Settings.
    (Seems like it works by eSnaps in status bar too)
  • I found a method to work, I used "restore to default" option in settings, looks like a bug, also happened when I use control, something do nothing and is need to restart. Looks like 25v need updates
