BIM Stairs
How to add:
  1. Mid-landing
  2. Intermediate landing
  3. Half-landing
  4. Mid-stair landing
  5. Center landing
… to my stairs without explode?
  • Hello.
    The stairs don't have a type or a configuration property.
    They are blocks containing other entities, like 3D solids and array of 3D solids, created based on the input options.
    Also, the parametrization is created based on the input options.
    So, the block could be edited and the geometry changed, but the parametrization needs also to be adjusted according to the changes.
    One way of working could be to create a new stair as desired in a test project.
    This way, the geometry and the parametrization will be created without any further editing needed.
    Then you could be to open a copy of the new block, with BMOPENCOPY and save it in a separate file.
    Then, you could use BMREPLACE > From file, and replace one or more stair instances in the model with the new stair drawing.
