In BricsCAD 25v can not use "Fence" selection option
I tested BricsCAD 23v and was working perfectly trim+fence.
Now, I tested BricsCAD 25v and is not possible to use Fence selection anymore.
Was changed the method to use Fence selection? or was removed this feature?
V25 introduces a quick mode, which is also the default.
To get the Fence option you need to change the mode to standard.
Alternatively, you can turn TRIMEXTENDMODE off, which will return TRIM to the previous releases mode of operation.
2
