V25 Quick Select Tool Won't Add To Toolbar
Greetings: Tried to add the Quick Select Tool to a custom toolbar. It appears to work but once the screen refreshes it defaults to the Select Tool.
Any ideas how to make it stick?
  • Hello.
    You should check how the tool was added to the toolbar.
    Specifically, what expression is in the Command field, in the Customize dialog box.
    It should be:
    ^c^c_qselect
    If it is not, or if drag-and-drop doesn't help, then delete the tool that is not useful and, still in the Customize dialog box, use right-click on the toolbar name and choose Append tool.
    Then select the tool from the list.
    Quick Select is in the Edit toolbox.
