Extrude to closed polyline create walls
I wish to create walls extruding closed polyline, and then I wish to cut solids in their edges to generate BIM walls
How can I do this? (cut)
Took a while to find ….
BIMSPLIT
(from the early days of Bricscad Direct Modeling, but great Tool)1 -
cool.
Nice feature, but I find a problem, when I extrude and split, other features ignore these solidsIn the image, I try to use push / pull to the wall face, but the solid is ignored and select the slab created with BricsCAD BIM tool.
Also, when I try to change story level bar height range appears deleted objects in the sectionI used Subtract to delete the center solid, but it still appears there.
