V25 Attach .DWG issues
Hi All,
We have a couple of computers with the V25 installed and using to find any issues, and we seemingly have found one.
Attaching files, we have the settings at global co-ords, scaled at 1 and rotation of 0 deg. The attached files appear rotated ccw 90 degrees. Detach and attach again changing the roation to 90 deg and all is where it is suppsoed to be.
After chacking on V24, rotation is defaulting to 0 deg and the attached files are where they are supposed to be.
Firstly, has anyone else found this issue as yet, and secondly, apart from changing the rotation to 90 deg, anyone found a setting to correct this?
  • Hello.
    With using some drawings created from scratch, the only case when I could reproduce a rotation was to use some custom coordinate systems.
    What happened was that the WCS in the xref was mapped to the current UCS in the main drawing.
    In my testing, V24.2.07 and V25.1.05 worked the same.
    Does the issue occur with any drawings?
