Selectioncycling
When I hover over overlapping entities I see the Selection Cycling dialog box, (Variable Selectioncycling > 2) it only allows me to select a single entity. Is there a way to select multiple entities from the dialog box?
It seems, there is no such a possibility yet.
I wonder what the point is this command. I set it to 0.
It allows to select one of overlapping entities from the dialog with a list of entities under cursor, not cycling them by TAB.
When it works; after some time (don't know why) dialog starts appearing blank - quite annoying.
