Batch convert milometers to meters as drawing units
I tried to write a lisp but leave error "defconst", no idea how to solve because new in BricsCAD
(defun c:MM2M (/ folder path scale-factor files) ;; Define the scale factor from mm to m (setq scale-factor 0.001) ;; Prompt user to select the folder containing the DWG files (setq folder (getfolder "Select folder with DWG files to convert")) ;; If a folder was selected (if folder (progn ;; Retrieve all DWG files in the selected folder (setq files (vl-directory-files folder "*.dwg" 1)) ;; Process each file (foreach path files ;; Open each file (command "_.open" (strcat folder "\\" path)) (princ (strcat "\nProcessing file: " path)) ;; Scale all entities in the drawing by 0.001 (command "_.scale" "all" "" '(0 0 0) scale-factor) ;; Save and close the file (command "_.qsave") (command "_.close") (princ (strcat "\nFile saved after conversion: " path)) ) ) (princ "\nNo folder selected.") ) ;; Completion message (princ "\nAll files in the selected folder have been converted from mm to m.") (princ) )
Ok maybe a simple answer, once the code hits this line and opens a dwg that is the end of your lisp file, a lisp can not continue onto a new dwg, you can use a script and open a dwg, load a lisp and run it, use (yourfunctionname) as last line etc dont forget the C: if in defun name.
An alternative is because task is simple you can use OBDX, it modifies a dwg without opening it. Check out Lee-mac OBDX just google.
1 -
Rather than rescale the objects, you could reset set the units from unitless or millimetres to metres, so that 1 unit = 1 metre.
1 -
The real problem i found is that i need rescale line type, layouts, dimensions, and problably more things
Using Ltscale and in layouts the viewports Psltscale can help. Dimensions can have a scale factor so 2400 becomes 2.4, look at dimlfac.
1
