Attributes not being moved by parametric move / stretch
Hallo I applied a parametric move and stretch to a text attribute and I always have to update the view using attsync. Is there a way to apply move to the attribute without having to attsync all the time ?
thanks
Luca
2
Hello.
There is an issue with moving and stretching attributes.
This is currently under investigation.
So, for now, a synchronization is needed to have the attributes in the right position after adjusting the block.1 -
thanks noted - can you revert once this is solved?
Regards
Luca
Any update on this?
1 -
I have a similar problem.
Neither moving nor stretching works
Any update on this? Still not able to move attribute with Stretch operation.
1
