Is it possible to import Co-ordinate Systems?
Here in Northern Ireland, there are several grid co-ordinate systems that over lap and depending on the architect, depends on what grid system is used.
The problem I have now is the architect has used Irish Transverse Mercator for his drawings and the drawing to be submitted to Irish Water has to be Irish National Grid.
BricsCAD has got the Irish National Grid (TM75) but it does not have Irish Transverse Mercator.
Is there a way to import grid systems to BricsCAD and if so, where would I start to look for the grid system to 'download' online.
Thanks in advance
Have you imported the CSMAP Overlay for BricsCAD? It contains numerous additional systems and provides more precision for existing ones. See the "About CSMAP" section at the bottom of this BricsSys page.
I have yes but it still does not include it.
You could try raising a support request to ask for this coordinate system to be added.
If your confident you could add the coordinate system yourself. Details on the structure of the geodatabase.xml can be found here.
