Block text attributes reset position after restart
I have a block that I use to indicate coordinate points. After importing all the locations some of the text attributes that display the point references are overlapping, so I move the attributes manually to be readable on plan.
Sometimes after saving, closing, restart and reload the block text attributes all appear to be have been reset to the default location. However, when I attempt to move them using the grip, they "pop" back to the customised location. So it appears that the custom location is retained, but not loaded correctly. I've tried to regen/regenall but this does not work.
Is this something I am doing wrong?
Is there a way to prevent this?
In the short term is there a convenient way to restore the custom locations for any blocks this may have happened to? (without having to manually manipulate the attribute grip for every block).
I've attached a video of the behaviour.
Also, a dwg containing one of the blocks.
Hello.
I noticed the issue as shown in the video, but I couldn't reproduce it with the attached drawing.
So, I am not sure about what could be of use here when the issue occurs.
Maybe experimenting with the ATTSYNC command would help.0
