Reverse Direction of a Polyline
Hello, I m new here, so Hi to everyone.
I ve installed BricsCAD some days now and I can say I m really happy.
I was using Acad. I need to reverse the direction of a polyline with one command, just how Im used to do. I don't remember the command I was using because I customize a lot (it was just the "R" command… I think it was the REVERSE Acad)
Now in BricsCAD I have to PEDIT and then press R to reverse the polyline
Is there a way to do it in one step? One command solution?
Thanks a lot
  • Hello.
    In Bricscad, the REVERSE command is not defined.
    The simpleset way of working seems to be to create a button tool using an expression like:
    ^C^C_.pedit;_r;;
    A more advanced solution would be to create a lisp function defining a custom command named REVERSE and have this function automatically loaded.
  • edited November 2024
    see attached lisp.
    PEDIT command have reverse function.
    using lisp save some clicks…
  • Thanks to all of you. It is very helpfull. Nice forum!
  • This is what I use to work out the start end point of a P/Line.
    (defun swapends (entl / )
    (setq pt (cadr entl))
    (setq obj (vlax-ename->vla-object (car entl)))
    (setq start (vlax-curve-getstartPoint obj))
    (setq end (vlax-curve-getendPoint obj))
    (setq d1 (distance pt start))
    (setq d2 (distance pt end))
    (if (> d1 d2)
    (progn
    (if (= (vlax-get obj 'objectname) "LWPOLYLINE")
    (command "pedit" (car entl) "reverse" "")
    (progn
    (vlax-put obj 'startpoint end)
    (vlax-put obj 'endpoint start)
    (princ)
    (setq ent (entsel "\nPick object near end "))
    (swapends ent)
