Wrong size of the inserted parts from the library
I'm experiencing issues with the size of some of the parts inserted from the library.
I create some components including some parts of the library such as screws. In the component itself, the dimension of the parts is correct.
When inserting these components in another drawing, in some cases some of the components have a wrong size.
The components are inserted as a component (BMINSERT) not as Xrefs.
Any clue of why this may happen? Any workaround?
I'm using Bricscad 23.2.06 (x64)
Regards.
  • It looks like it is an issue with the names. The problem arises when I insert parts which use the same library component and the name ends up being the same. For example:
    if the drawing A contains the screw DIN 7984 named "DIN 7984:1" and the drawing B the screw DIN 7984 named "DIN 7984:1".
    When both A and B are inserted in a drawing, the dimensions of the screws are not as defined in the drawings A or B.
