Automatic BIM-Properties in Compositions and Blocks
edited November 2024 in BricsCAD BIM
I want to create Blocks and Compositions, that already have a BIM Property set to a certain value.
For Example a Wall Composition, that always has a Fire Rating of 30 Min. (These Properties should ideally map directly onto IFC, even better if it's a custom BIM-Property)
The same for Blocks: For example a door Block, that when placing already has a BIM-Property set, where I don't have to manually change it. For example a Door which always has a Fire Rating of 30 min.
Edit: Would it maybe even be possible to have an Attribute in a Block that directly maps onto a BIM-Property?
