Enrity cannot be treated (copy\move\rotate etc.)
I recieved this table entity made in other cad software, and cannot do nothing but to explode this table to be able to move\copy, for example..
Is there a way to treat this ?, pls. see att. table.
Regards.
Meital.
  • The EXPORTTOAUTOCAD command in V25 will create a new drawing with the proxy converted to entities. You will need to explode to access the linework and the text. If you don't have V25 you can SAVEAS to an old format like Release 14.
