Comparing "Plot to PDF" - C3D vs BricsCAD
Hi
Just tried to plot dwg with ortophoto image attached with "Plot to PDF" printer used.
PDF plot file made from Autodesk C3D has size of 2.7 MB
PLF plot made from BricsCAD has size of 125.4 MB.
Used same file on same layout from one software and then in another… PDF file quality is visually the same.
Any hint from anyone?
If you edit the plotter configuration of "Print as PDF", then you will find options to change the resolution of the raster image.
