Moving attribute
edited December 2024 in 2D Drafting
I have an application that, via a script, inserts, for example, 10 blocks, with attributes, and moves an attribute, in the first block, to the left. Other 9 similar attributes will be hidden. If I choose to show another such attribute, I need to move it a little to the left and then I first need to change snap to 1, move, change snap to 5 again. (Edit: or point direction and enter 1)
Is there command or script to make this easier?
I have tested with LeeMac Attribute Modification Suite and it works but then the first attribute is also moved further 1 unit.
  • Aarr.lsp from https://cadtips.cadalyst.com/attributed-blocks/copy-attribute-position works fine!
