Sheetset manager not renaming connected DWG files
Hallo
I have created a sheetset to manage files, and its very convenient but now I had to rename some drawings and change the order/number. What I found out is that the sheet set manager has NOT renamed the underlying / connected files, so now all filenames are completely uncoordinated.
example:
"ID-106-00 elevation" points to a file named "ID-104-00 elevation"
Is this correct ? does this mean when I rename a sheet in sheetset manager I have to also rename the file ? isn't this cumbersome or am I missing something ?
thanks !
Luca
Hello Luca,
Such an option, to rename file name, when sheet is renamed, is not implemented in BricsCAD. So you need to rename the file separatly. We have a feature request task for this, you can send a support request to add a value to the task.
Best regards,
Lyubov1
