Properties Panel
in 2D Drafting
good evening - BricsCAd Pro on MacBook Air M1
The width of the right properties panel and commondline panel which are stacked are so narrow i'm unable to see all the information fully. When i try to drag the panel wider it does not respond.
Can you help me ?
You probably have Lock UI enabled.
Usually you can find the Button at the right in status bar.
In V25 it may be hidden. If you click on the 3 points you can select which entries are shown in status bar and can bring it back.
The fastest way to temporarily edit your UI/palette sizes, although UI locked,
is by holding CMD when dragging0 -
Thank you very much zoomer. it was driving me crazy!
