grips editing
I am trying to creat an object and the staring point is 20x20 mesh.
I then need to edit the mesh by stretching the grips.
I can click the grid and then hold shift and select indidvidual grips, but thats prettty tedious and more annoyingly; the slightest misssed click deselcts and you have to start agian.
Is there a way of selecting multiple grips in one action, rather than one at a time?
I don't see another way to select multiple grips, exept pressing Shift and click grips one by one. But for stretching you can run Stretch command, then use selection window - grips inside the selected area will be moved.
