How to replace all windows (same block) by another window?
V25 introduced a huge problem with sketch feature and affect models made with previous versions if opening them in V25. I adapted and expanded the BIM exercise from Bricsys used for several years for my BricsCAD BIM training. No problems before V25, everything worked perfectly.
In V25, the window created looses subtraction and has to be remade from the beginning (image 1)
For the next intermediate exercise files, I want to replace the wrong window with the corrected one. Is there a way to do this? BLOCKREPLACE doesn't work, as there insertions are anonymous.
Found it. Command BMREPLACE 😀
2
