Insert Selected Quantity As Field
Is there any method to use the selection object's quantity as a field? Maybe with groups, but How does this with lisp?
Hello.
You could use ExtensionProperties from the Extensions category.
Then, select the object, choose Quantity in the Property category, and pick a property.Regarding lisp, you could experiment with some of the functions provided by Lee Mac.
2
