how to create a TIN Volume Surface
edited December 2024 in 3D Modeling
hi, how to create a TIN Volume Surface in V25, in v24 the command was tinextract. In v25 this command does something different.
  • Hello,
    You can use TINVOLUME command to create a TINVOLUME surface between a base and comparison TIN surfaces or an elevation.
    TINEXTRACT command extract entities from a TIN surface.
