Weld symbols does not show
Hello,
I've some issues with the AMWELDSYM command. It simply does not show anything other than a straight line in the drawing. I have access to the weld properties but it simply does not show. Anyone have been trough this?
I'm currently having the same issue, did you ever figure this one out?0
I am using BRICSCAD V24 on Ubuntu 22.04.S LTS 64 bits.
The machine I use is a Dell G7 with:
16 GB RAM
Intel Core i7 2.2GHz
NVIDIA GP107M [ GeForce GTX 1050 Ti Mobile]
The dwg I am having problem with:
Last time I started a new part and things ended up working out. But now the same happened again and i could figure somethings out:
- The problme starts after rotanting the part in the model space. I ended up doing so to change the front view and make it easier to work;
- If I copy and past the part in a new document and dont change it's oriention on the model space the weld symbol works;
- If I execute AMSETUPDWG for the 2d commands before manipulating the 3d object, the weld symbol works fine;
- In the case above, as soon as I delet one of the layout tabs, the weld symbol turns into a straight line, like its plane was rotated 90°. And if I undo the action (crtl+z) the problem stays the same.
- If the object is not rotated it does not mather if i delet or not the layouts;
One other thing I am not undertanding is that, when it is working, as soon as I save the file the weld object turns in to a block and loses the color properties I had made and the possibility of editing.
