Exporting DWG to something that ZWCAD can open?
Hi, we are trying to open files created with BricsCAD using third party apps to check export and import capabilities. We are unable to open the default generated DWG files with ZWCAD, for example. The file has a TIN, its corresponding contours and some 3DPoly. Is there something that makes those DWG incompatible or something that cab be done to improve compatiblility?
Thanks in advance, Jose
  • I would think not since it’s a BricsCAD feature. You may be able to explode the objects
  • @kanksmuso
    as @Its_Alive wrote - mabye TIN surface is a fearture that Zwcad can't open.
    to keep the topograhfy information extract the contours from the TIN surface using "tinextract" command.
    it will create the contours as polylines with elevations ("Z" value).
    then delete the TIN surface.
    hope it will help.
  • ALANH
    edited March 2025
    We always gave an external client a TIN (civ3D) and 3dfaces so they could make their own TIN. As we had added breaklines etc eidted TIN it was good to go. Civ3D had a exporttoCAD function like "Tinextract"
