Panning and crashing
I keep getting a fatal error while I pan around or zooming into a different area of the drawing.
I am using V25.1.07-1-en_us under civil survey. My drawing is small and only has survey points and line work and a few blocks.
  • I received this from Bricsys support: Can you set MTFLAGS=0 and test if the issue still occurs?
    Best regards,
    Andreea
    This has fixed my crashing problem…
    Thanks,
  • Hi everyone
    I'm also having problems with V25.1.07-1-en_us crashing to black screen when panning /zooming using shift etc. This seems to have happened after the latest update as I it was stable for the entire time I beta tested V25.Support have not been able to help.
    I have an AMD pro wx3200 card and AMD ryzen 5600. Does anyone have any advice as to settings that may help? All drivers are up to date and I have tried to roll back the Graphics driver to no avail.
    Thanks.
