Error 3:The system cannot find the path specified
Hi All,
When loading a .lin file, I receive the below error:
The path BricsCAD "can't find" is not the path I selected, and after clearing the error, I am able to load line types as normal.
Is there somewhere where this Q drive path has been saved? I've had a look through Settings with no luck.
Thanks,
Ash
I get a similar error when I open Bricscad BIM Demo File.
Looks like some resource does point to that path of a Windows machine.
But I also do not notice anything missing or working unexpectedly.Maybe Bricscad finds that resource in one of the standard paths anyway and does just moan about the path (?)
A mystery indeed!
I agree, nothing is missing or working incorrectly. I will continue to close the error unless I magically stumble across the path location.
