BricsCAD Command History and Position Lisp properties
You can use Logfileon to write a file its saved to your temp directory can be huge and you can look at it any time. Use logfileoff to turn off or svae as individual files with on & off.
1 -
Hello.
Aside from LOGFILEON, something of interest could be to experiment with the SCRLHIST system variable.
This variable controls the number of lines in the command line history.
1 -
thanks, each day I love more BricsCAD
