Crash when I try to make an array with parametric text
I am trying to make a parametric block where I can set the number of rows in the contained array as a parameter. Each row needs to have parametric text as a description. The idea is to make PLC card creation easier within my drawings because they all have different quantities and terminal tags across manufacturers.
As soon as I try to make an array containing parametric text, Bricscad has a fatal error and crashes as soon as I click "rectangular" during the array creation. Why is this?
The quickest way to cause this crash is just "Define Attribute" and try to add the produced text to an array. Immediate crash. The same thing happens if I choose polar instead of rectangular
Hello.
I couldn't reproduce the crash.
However, attributes cannot be used to create associative arrays.
Something of interest could be to experiment with the ARRAYCLASSIC command, to create independent entities.
