Bricscad v25 is stuck when trying to import IFC file
Any help is blessed
yaron
  • Hi meitalw3,
    Importing with the setting "Import BREP geometry as meshes" enabled, allowed me to import this IFC file. But, of course, BREPs will result in meshes.
    In case you want to import those as 3D solids: there seem to be issues with invalid geometry in this IFC file, preventing the creation of valid 3D solids.
  • meitalw3
    edited February 2025
    Thank you for your answer
    I opened the file in Autodesk Viewer.
    Regards
