Disable "Fillet" joining lines into a polyline
As it says in the title, looking to stop the seemingly default action of fillet joining the lines in question into a polyline.
  • Hello.
    The behavior is similar to the one in Autocad: if one of the "lines" is a polyline, the result of filleting is a single polyline.
    To get individual segments, an EXPLODE is required, resulting in lines.
    If polylines are required, after exploding, use PEDIT with the option Multiple.
  • It won't do that unless one of the lines is a polyline.
  • You could make a custom version of the Fillet command, one that automatically explodes the new polyline.
    (defun c:Fillet2 ()
    (command "Fillet")
    (while (> (getvar "cmdactive") 0) (command pause))
    (command "Explode" "L")
  • Thanks all, I was woindering if that was the case but it seemed to be doing it whe nI didn't think I had any polys in the line. I think what I'd done is use 2-point rectangles to quickly draw out piers on walls and not exploded them.
