Flatshot Problem V25.1
In previous versions, when there were hidden entities, Flatshot would create only for the visible solid. Now, it creates for all. Is there a variable or setting I can change to make it generate only for the visible solid?
  • It would be useful to get the drawing itself, not only a picture, to check the behavior with a proper example.
  • I concur with this, but it does seem to be only when the hidden entities are block
    @Lyubov Osina play with the attached.
    The middle cube is a block. Hide it and Flatshot, it still appears. Hide the layer and Flatshot it does not
  • Hi @RussC , thank you for example, I can reproduce the described behavior in V25.1, but as I see, it's corrected in V25.2.03.
  • Oh, okay.
    Waiting for the update on that one
