Show the formula in properties instead of just the outcome?
I regularly use a formula in the Misc. field in an array. A total length divided by a number X. Works great. But sometimes I want to change the number X. I find that I have to redo the input for the formula. Is it somehow possible to retain the formula when editing the column spacing?
Would be a very welcome feature if not yet available?!
  • Hello.
    If this is about the Misc. section in the Properties panel, then, with the array selected, after clicking in a field, there is an fx button at the righmost side of the field.
    Clicking on the fx button switches between value and expression.
  • I found that button. But it doesn't show the formula I entered, only the outcome with an '=' sign in front of it.
